NO data comes up , in order to work everything should be wired and connected [ esp32 <---> RS-485 module <---> Inverter ] and esp32 and RS-485 module are ON , Then restart the inverter ---> Works !What happens if you keep your RS-485 wires (you are using 3 wires, right?) disconnected from either the inverter or the RS-485 module, power up all equipment, then connect the RS-485 wires?
