Thanks for the reply. I also noticed that the TX led on the arduino does not keep flashing while the code is executed. Only the RX LED is flashing.Well, ideally you would remove the resistor, but since that requires solder work, perhaps it's easier to connect idle biasing resistors between 5V and Data A and between Ground and Data B as shown in the Example RS-485 Network Diagram here:
