I'm encountering a problem in my Project for the procurement of Pneumatic spring return ESD valves. In the Sizing calculations, for some valves the Actuator MAST is exceeding the Valve MAST, which I believe is not desirable.
I cannot change my DP on line & cannot reduce my safety factor (2). What is the solution now?
Can i proceed with Actuator MAST higher than Valve MAST?
Thanks in Advance!
Cheers
Thanks in Advance!
Cheers
