I've recently had an issue with five (so far) Auma actuators shorting out through the solid state starter on power up. These are new actuators, but all five had previously been powered up and tested. During the course of our start up, power was turned off to each actuator at the local disconnect. When power was turned back on at the local disconnect, a loud pop was heard inside the actuator and the main breaker feeding the actuator tripped. With four of the five, this happened immediately on power up. With the fifth actuator, this happened about a minute after the disconnect was flipped on, right at the end of the actuator's power-up sequence.
In the image, you can see that there are visible burn marks on L1 and L3 and the line side connector was blown off the starter. My theory is that during power up, perhaps the actuator's electronics try to open and close at the same time, and the starter's reversing interlock failed. That's the only thing I can think of. Has anyone else out there seen this before?
