ahdash
this is normal, as every machine had different behavior, this is related t the efficiency of each machine? You try to calculate it as per your machine OEM .
you did not mention about other measurements such as inlet air mass flow in m3/hr, you measured pressure and temperature pnly which is not enough.
One factor may affect the efficiency the mass flow is the inlet filter pressure drop (delta p) you check this point as well.
Also both compressors cleanness is a major factor .
Good luck
Good luck
