Greetings:
I was just wondering how full load current ratings were calculated for brushless AC Servo Motors (Permanent Magnet Rotors). The motors have nameplate ratings in kW. I have used the following formula from 3 phase power systems. i.e.. Power (kw)=3DSqrt(3)*VL*IL*Cos(theta).. where the dc bus of the power block (Pulse width modulated) is 300v dc (600 V peak to peak via the gating IGBT transistors). Therefore if you assume a "Normal" sinewave output (PWM) the RMS value would be approximately 212 V (300Vpeak/(sqrt2)). By plugging these values into the above equation.. once again assuming a unity power factor (Cos(theta)=3D1) you can solve for IL. I usually multiply it by 125 % and get an answer that is relatively close to data sheets supplied by the manufacturer (Jenglish data sheets..hehe); However, you know what happens when you ASS UME. One thing that I do know is that these motors can dissipate great amounts of heat; Therefore is there some type of rating / class factor that I am missing? If it matters, the motors are manufactured by Sanyo Denki.
I would appreciate some feedback so that I can calculate these motors more properly.
Thanks In Advance:
Stephen Bennett
Kawasaki Robotics (USA), Inc.
Thanks In Advance:
Stephen Bennett
