In a general sense, no. Under some very special circumstances with only two devices on the bus you "might" be able to do some things using the CAN protocol over RS-232.
The thing is that CAN used pullup resistors on the bus as a way of detecting if there is a packet collision. The node with the higher priority address wins the packet arbitration. (CAN bus defines everyone as a Master and Slave, so Collisions are very possible.) In short, RS-232 is not going to cut it for you. CAN goes as far as making silicon to do this packet handling and error correction. Interface chips are cheap, I know you can find a bridge or adapter to interface your computer (or device) to CAN.
CAN bus does not have collisions. It avoids them with the priority arbitration protocol in the CAN ID field. Also, CAN is not a master/slave system. It is peer-to-peer. There are protocols built upon CAN that do define a master/slave relationship, like CAN OPEN, and Device Net, but they are something above CAN and not CAN itself.
As for RS-232, that defines a single-ended bipolar voltage physical layer. CAN is a differential voltage on two lines. If a hybrid were made of CAN and RS-232 it would not be either.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
I am planning to monitor the engine of an 8kw generator's Can-bus over the web via a PC using a Can to RS232 dongle connector from http://www.can232.com
Is that a solution to the above question?
Does any one have experience of using these dongles and/or advice regarding my project?
