Cimplicity 2022 PointGet Latency
Hi all,
I am working on a Cimplicity 2022 project less with Advanced Viewer and ControlST v7 under Windows 10 and it works perfectly.
I added new values on an existing screen to display the scale in Metric or US engineering unit (EU), I used PointGet (script) to assign the EU scale of each value but when opening the screen with cimview i remarked that each value take 1 second to display the scale and take 10 seconds to display the 10 values.
I temporary disabled PointGet from the script then the screen displays directly without any latency.
ptopc update rate is 50ms and its ok becasue all the values are refreshed normaly
Is there any parameter to set to increase getting data using PointGet Methode?
I know Windows 10 is slower than Windows 7...Is is Windows 10 issue?
I stopped Windows Defender, clean boot...but same result.
Is there anything I have messed?
Thank's for help
Dino
Cimplicity 2022: Swift PointGet latency ensures real-time responsiveness, enhancing efficiency in industrial processes. Elevate your operations with cutting-edge performance.
Thank you for your reply.
I did not understand "cutting-edge performance"
how to elevate the performance ?
The Cimplicity v11 is working great but not 2022.
I tried also 2023 and same thing when using PointGet in script.
Hi All,
New update,
I created a project workbench then PointGet is working properly, there is no slowness when updating data when using PointGet in script but when I start the project as viewer there is slowness to update data.
Is there any parameter to modify to resolve this issue.
Thanks in advance for help.
Dino
