Communication between Telemecanique to ControlLogix PLC
V
Vinnie
I am trying to establish the communication between Telemecanique PLC to AB ControlLogix PLC. I have few Telemecanique PLCs on Modbus TCP/IP network. I want data to and from these PLCs into ControlLogix PLC. My ControlLogix PLC is on the different EtherNet network than the existing Modbus TCP/IP.
Please suggest me a best possible method. Currently I am reading on using the cATM module by oldi.
Thank You,
Vinnie
Darrin Hansen
Our ETH-1000 Ethernet gateway can simultaneously act as (among other protocols) a Modbus TCP client and server, as well as EtherNet/IP client and server. So moving data between these two PLCs is not a problem. Pricing is currently US$525.00 @ qty. 1:
http://iccdesigns.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=ICC&Product_Code=eth1000
We even have an application note that discusses how to move data in & out of a ControlLogix:
http://iccdesigns.com/downloads/documents/general/Accessing Data on a Logix PLC with the ICC ETH-1000 Ethernet Gateway.pdf
Darrin Hansen
ICC, Inc.
