I am doing a telemetry system which consists of 16 CompactLogix PLCs and esteem 195es radio modem. This is a DF1 master and slave configuration.
I have set up the serial port of the PLC to be DF1 Master for 1 PLC and DF1 slave for other PLCs. I have set up the polling mode to standard (multiple message transfer per node scan) and created tags for other settings.
First, I tried the PLC on a point to point comm setting on the modem. It worked (point to point). The problem I have is: I tried to change the modem to use multipoint and the PLCs failed to communicate with each other. Has anyone used the esteem 195es modem and CompactLogix on a DF1 protocol? I would like to know how you configure things.
