I
Dear colleagues,
thank you for dedicating your time to answering my question.
I am working on my graduation thesis to design the electrical installation connecting a CSP plant to two loads. Below are the project guidelines:
* CSP rated power = 1 Mwe
* Load A
* Load B
- The CSP is connected to a 22kV grid.
- The CSP will power load A first, and if there is an excess in power generation it will also power load B partially or entirely (depending on the excess).
- The CSP and the utility grid will both power load A if CSP power output is not sufficient; load B will be powered by the utility grid in this case.
Are there any books or technical resources I can use to design this electric system? Are there any special equipments that should be in use?
Thank you very much for your help. All the best.
* Load A
* Load B
