Hello!
I'm using a TSX Momentum PLC (171CCC96030) with Ethernet interface.
The problem is, that i can't connect to the device using the Concept Software or even ping it using the Windows XP command console.
The device is connected directly to my pc with a crossed ethernet-cable. I know its IP and the Mac-Address and i turned the firewall off.
I found out, that it works if i have the software Ethereal running in the background.
Does anybody know a way to communicate with the PLC without Ethereal? Because i don't think this is the intended solution of the manufacturer.
I'd appreciate any help solving this problem.
