I have a chiller application where in i need to maintain the Chilled water outlet temp at constant 1 deg C. even if there is a change in the Chilled water inlet temp by 0.5 or 1 deg still my system should deliver constant 1 deg C output. The final control element is a steam control valve which controls the steam flow to the system. I will be using a 3-wire PT100 sensor at inlet & outlet of chilled water for the same.
PLease guide me how i will be able to achieve this requirement.
Thanks..
Thanks..
