HI All,
We have one Aluminum CAN printing machine which is driven by 100HP DC Drive and motor.This was a six color printer and was upgraded to 8 color last week. Since then amps of the motor is very high. it was drawing 125Amps at 1500 CPM and after upgrade we are able to run at 600CPM at 180Amps which is full load for Drive (motor full load is 160Amps). We already changed motor but same amps is drawn. We have similar machine running on other line with 140Amps at 1500 CPM (Cans per minute). To prove machine is not the problem we decided to feed the motor power from the running machine panel and amps went down to normal. We checked voltage and it is 315VDC with 140Amps at 1500 CPM.
What could be the problem of Drive.
We are using Reliance DC Drive Flex Pak 3000. Model # 100FN4021
Thanks & regards,
Shree
Thanks & regards,
Shree
