I have seen that in some emergency shutdown application is recommended to use a double block and bleed valve arrangement.
Could somebody tell me if each solenoid is connected to a different output channel in the control system or if it possible to use the same output channel to energize both solenoids for the two block valves?
Thanks,
Sergio
Thanks,
Sergio
