We have a S5 90U, which appears to have lost it's program. PLC was found in stop mode, has been returned to run mode, inputs are on but outputs are off. This is one of 10 PLC's and all the others (same function different HRSG's) have the outputs energised. We are attempting to upload from one of the healthy PLC's (as we don't have a back up!) and then download this to the suspect one. The equipment we have is very old and we have little experience of it.
Software is S5/ST version 6.5 (dos based) on a PC
We have obtained two cables one is 6ES5734-1BD20, the other is 6ES5734-2BF00.
We are trying to connect to a S5-90U – 6ES5 090-8MA01
Are either of these the correct cables?
The prommer is set to External Prommer with parrallel port - LPT1
When opening Step 5 we get the following messages;
STEP 5 LPT-Prommer EPROM-DRIVER V4.07
EPROM TSR at LPT1: Please check PROMMER Port, Cable and Power !
ERPROM TSR was not installed !
Error by loading EPROM driver
Press any key to continue . . .
The software then opens, but it appears that we have no connection. This being based on settings Page 2, selecting the mode (which states offline) and after this it states PC timeout.
Is this simply due to the cable we are using or could there be other issues?
