Dear Friends,
As per the specifications of the AB make analog module 1769 IF4, the resolution is 14 bit. To get the adventage of the accuracy, I wanted to use the same to control temeperature where one can set the preset point in floating point (e.g say 23.5).
While writing the code, I find that the PID block setting of the Micrologix 1500 PLC accepts set point (e.g PD10:0.SPS) only in the integer form.
How can the problem be solved simply but without comprising accuracy?
