OK. The 4-1, 4-2,4-3 & 4-4 are 125v relays and these are used in the Emergency Push button trip circuit. The contacts from these relays are then used in a 2 from 4 circuit which takes it's 24V power from the three TCEA cards in a high select circuit. The 24V power is then used to energize the ETR & PTR Relay drivers (See Page 59). (Be careful, there is a small mistake on this drawing. The JLX/Y/Z relays are from XYZ on the TCEA cards not RST as shown on the drawing.)
So the logic is that any Emergency Push Button operating will dump 4-1/2/3/4 and dump the 24V signal to the PTR & ETR relays thus tripping the master protective.
Hope this is clear, please reply
