Well I would say that its up to you man!How long can a gas turbine run without electrical load? (without generator synchronization system)
Ok You surely mean HRSG ....So what is your opinion ...Hi,gas turbine runs at start-up for about an hour due to steam in the GRSG
Merabiko8,
Actually, the answer depends on a lot of issues--the biggest of which is the type of combustion system. If the unit has conventional combustors (diffusion flame combustors)--which includes MNQC combustors (Multi-Nozzle Quiet Combustors) it can probably run for a couple of hours without any problems, maybe more. However, if the unit has DLN combustors, particularly DLN-I combustors, then it probably would NOT be a good idea to run it for more than an hour or so (because of the heat of the diffusion flame, the low IGV angle).
If the gas turbine exhausts into an HRSG (Heat Recovery Steam Generator), that may have an effect on the total running time. If the HRSG has auxiliary duct burners (auxiliary firing) it would probably NOT be advisable to try to run them without load, and with the IGVs not fully open. (That doesn't mean you can "force" the IGVs open to bypass that--that is NOT acceptable, ever.)
You might find some OEM (Original Equipment Manufacturer) information in a GE publication, GER-3620 (I believe that's the publication number). It's kind of difficult to read because it tries to cover every possibility for just about every frame size machine is as few words as possible. But, it's probably the best document for this kind of information (and any other operating information, as well). I don't have a copy to send to anyone; use your preferred World Wide Web search engine to find a copy. (I think Revision R is the latest, but I'm not even sure about that anymore.)
If you absolutely have to run the unit without any load, please watch the wheelspace temperatures closely, and if they start rising, and rising quickly, that's not a good sign. And, also depending on the combustion system and the programming in the Mark*, the compressor bleed valves might not be closed at FSNL with no load. So, that means the unit is going to be very inefficient (burn more fuel than even at very light load with the compressor bleed valves closed), and the internal cooling might also be adversely affected. AND, pay attention to vibration! If it starts to increase on either bearing, and starts to increase quickly, it would be best to shut the unit down.
Hope this helps! Best of luck!
Thread starter | Similar threads | Forum | Replies | Date |
Gas Turbine (GTG) compressor discharge increase with load | Power Generation | 1 | ||
What is GE's gas turbine 'CA_CRT'? | Power Generation | 2 | ||
T | Gas Turbine Premix combustion mode | Power Generation | 2 | |
Y | Legacy Alstom Frame 6B gas Turbine Ventilation Fan 88BT | Power Generation | 4 | |
Gas Turbine Pmax | Power Generation | 0 |
