V
Presently we are using IL make pressure control valve (PCV) for controlling the pressure (60 Kg/cm2 to 30 Kg/cm2) of natural gas of inlet of Gas turbine (Frame-V). PCV actuator diaphragm is operated by instrument air as per signal from DCS.
Instrument air is supplying by instrument air compressor. Presently we are having problem in compressor to run continuously, and we have to stop instrument air compressor permanently.
Without instrument air we cannot operate the PCV in auto and not controlled the pressure of inlet of gas turbine. As per our present situation, only air is required to PCV & ESD of gas turbine. No other requirement of instrument air. So we have to run compressor only for gas turbine inlet pressure control valve & ESD.
We want to know, there is any feasibility to operate the PCV in auto without instrument air so that we can run the GTG?
Is any feasibility to change the control valve by operating itself by fluid instead of instrument air pressure?
I have checked 3-4 sites but all are having PCV is operated by instrument air only. Please guide me if feasibility is available and what have to do.
