H
We are commissioning a GE MS5002C gas turbine mechanical driver. At 20 % crank speed, the hydraulic oil pressure developed by main hydraulic pump is 77 bar against the required 80-85 bar. The question is what should be the hydraulic oil pressure at 20 % crank speed? If the pressure at this speed is not adequate, what should be the probable cause?
[email protected]
[email protected]
