Dear All..
please provide your views...
G.E frame 6 gas turbine mark 5(30MW) was on full load. Load reduced to 24 MW to change over form fuel distillate to fuel gas. Gas valves were checked opened and pressure was all ok. Power factor at this time was .96 and voltage 11.14, vars 10. we have problem with one flame detector not sensing flame during normal operations.
now when the command was given to change over after 20 sec the load started reducing suddenly to 17mw then 12mw then 7mw then 4 mw then 2mw. after this point it jumped suddenly back to 17mw then 24mw.
During this time the power factor reached .76 and unity. Alarm came combustion trouble followed by loss of excitation and generator breaker tripped...
Also would like to mention we have avr problem so we regulate manually...and during the change over the voltage was being adjusted manually which was perfect......
WHAT CAN BE THE REASON OF TRIP?
COMBUSTION TROUBLE?
AND THE REASON FOR SUCH SUDDEN DROP AND INCREASE IN LOAD DURING CHANGE OVER?
thank you
detail from csa requested
COMBUSTION TROUBLE?
thank you
