In the application manual Appendix-B TCQA card definition, what is this SRV warmup time constant? Because it has been mentioned that, at startup with low level flow, the GCV is relatively closed and a small change in the SRV position produces a high rate of change of FSR. So interval time constant should be higher and vice versa in normal running condition.
Is this interval time constant the same as SRV warm-up time constant, and if this interval time constant to remain high during startup than what exactly happens?
Satyanarayan Pradhan
