in our gas turbine bearing-3 metal thermocouple BTJ32A has started spontaneous hunting from 113 deg C normal to a high value of 129 degC and more and to a lower value of 108 deg C; It all started after a high value of 118 deg C in BTJ31A and later shifted to BTJ32A. This shifting of "leads" by these thermocouples was happening for an year. The high value of BTJ32A then went to a second-wise hunting at a higher loads of 70MW and above and less than 50MW.. in between it is steady and not giving a hunting,, Also the BTJ31A is showing a steady about 113 degC. There is no spare thermocouple in bearings as per the new design of GE. Does the bearing is affected with laminar to turbulent oil flow during the steady BTJ32A - load margins. Does any of you faced the bearing damage after a similar event. Does thermocouple will have such a fast transients of reading?
Could your expertise show some lights..
