CTTech
Critics w/o Critiques by the numbers!
1. Introduction
Everyone should have goals.
2. Definitions
Karapetoff’s definition in 1911 was: "When carrying loads armature-current being a source of mmf, modifies the flux created by the field coils, thus influencing the performance of the machine." I did not extrapolate your preferred definition from Karapetoff’s definition. The keyword is performance. Performance is an energy balance. If performance changes, one can expect the energy balance to change.
3. Synchronous Generator Armature Reaction
I have learned nothing new is this section other than there is no 4, 5, 6, or 7.
8. Conclusions
I agree with your conclusions as long as we are assuming; except the unity part were excitation is increased.
In reality excitation should remain constant. Oh, there is no 9.
10. Addressing Incorrect A-List Responses Related to Armature Reaction.
Placing a dunce cap on someone will not have the desired effect.
I will now digress into oblivion.
I was once told that an inventor is an engineer that must sometimes question his education. Karapetoff addressed his graduating class with the same point in mind.
Karapetoff was also very big on teaching interpersonal skills to his engineers. He reminded to listen and learn.
I have learned from my arithmetic lessons that when performing calculations on numbers with terms one must carry the terms. Current is measured in amperes and the ampere is defined as a flow. Since the VAr depends on changes in field current then it would seem a VAr could or would flow. It is all about who decided to call an apple an apple isn’t it.
An oxymoron is sometimes used by an author to achieve a vision within the reader. Thunderous silence and sweet sorrow are examples. Perhaps reactive power was used for the same effect.
Assumption is the mother of the screw-up. The conclusion cannot be based on the assumption that terminal voltage is constant therefore we cannot summarize. We cannot assume that grid frequency or voltage is constant. The control system themselves induce some deviation because of the accuracy of the input devices and the algorithm used to respond to the setpoint.
For instance, the speed pickups mounted in close proximity of the 60 tooth wheel of a GE frame 7 gas turbine operating at 3600 rpm would have a sampling rate of 216000 hertz. Although a wheel with more teeth would reveal more accuracy in the speed measurement, the increased accuracy is not needed or necessary. All control systems have to be tuned in regards to the accuracy of the measuring device and the capacity to measure and react accordingly. I believe in measure, compare, compute, and correct. A control system can only react to a deviation from a setpoint therefore deviation must occur constantly and be reacted to constantly. The same applies to a voltage control system. Some GE EX2000 excitation control systems have a speed input feedback signal to prevent the system from overcompensating to voltage changes. I will now move away from the effects of the control system.
The grid must have constant changes occurring by design. I will choose the smallest quantity I can think of. An inductive motor bearing is not a perfect device therefore current flowing to the motor changes in some fashion due to the small changes in friction; however infinitely small. Another value that is infinitely small is the amount of time required for an engineering marvel to become and engineering disaster. In my opinion, the transmission grid is never constant in regard to frequency or voltage. The transmission grid is merely in a constant state of balance. The effects of load and how these effects are countered in the real world is what CSA described.
The concept of an infinite grid applies only to mathematics although it does have a definition. Infinitely finite is oxymora. A finite number of generators supply a finite electrical load connected to finite transmission resources at any given time. The only thing that is infinite is the number of things that can change the delicate state of balance of voltage and frequency that exists on the transmission grid.
I once had a professor that to my amazement was also the author of the textbook for this particular subject. The text within this textbook contained all of the knowledge ever obtained on the subject and all of the knowledge that would ever be obtained. No gray area existed on the subject for discussion. I completed the course with the same information that I entered it with. Perhaps, this is why I have not asked to read your paper.
Still stubborn,
CTTech
1. Introduction
2. Definitions
8. Conclusions
Still stubborn,
CTTech
