Grounding advice for an industrial load-cell PCB
Hi everyone,
I’m designing a small PCB for an industrial weighing system using load cells and a 24-bit ADC. The board will be installed near motors, vibrofeeders and contactors, so electrical noise is a concern.
Would you recommend separating analog and digital ground planes, or using one continuous ground plane with careful component placement? Are there any specific shielding, filtering or isolation practices that work well for load-cell signals?
I’m planning to manufacture the prototype through PCBWay, so I would appreciate any layout suggestions before submitting the design.
