We have GT Frame 9E with Mark Vie control. While fuel change over from Liquid to Gas, we are facing issue as explained below:
After giving command of fuel change over from Liquid to Gas, Gas vent valve before SRV closes and Shut Off valve opens but in the meantime inter valve pressure FPG2 becomes too high and machine takes shut down command.
During several attempts it has been noted that SRV opens fully i.e. 95 % when shut Off valve opens/Fuel change over command is initiated and P2 pressure becomes too high.
What could be the reason of this SRV full opening? the regulator gain is set at 2.5 while Null bias is 2.9.
Would appreciate support for resolution of this issue.
