Hello everyone,
I can not figure out how to know if a PLC will be fast enough for a project.
I have a set of 6 valves which I need to close simultaneously (or within 0.1ms). I have synchronous clocks hooked up to each valve to let me know when the valve closed and currently I am about 3ms off (fastest to slowest). So I want to write a program where I can delay each valve as necessary (to within 0.1ms) so that they all close at the same time.
Each valve is on its own digital output from the PLC with high speed relays in between.
What PLC setup can you suggest (Siemens preferred) that would guarantee me control to that resolution? Would it be more like an S7-400 or is a S7-1200 ok? Is it even possible?
Thanks for any help in understanding this.
Simon
Simon
