R
We have a 360 MW CCPP. For boiler make up & other usage we have a 20 m3/hr (20hr) capacity (400m3 before exhausted) Demi water train (2B3T) comprised of One SAC column(2200L), one mixed Anion column (30% WBA+70%SBA;1400L) and one Mixed bed polisher(300L SAC+300L SBA).
The outlet conductivity of MBP is 0.3~0.4 micro siemens/cm and the water from MBP directly goes to storage tank. There are two Demi water transfer pumps which supply to condenser as make up. There is a conductivity meter at common discharge of Demi water transfer pumps.
This conductivity meter shows 1.74 micro siemens/cm almost always. The storage tank has a top vent to atmosphere. We had experience the conductivity at storage tank 0.9 ~ 1.0 micro siemens/cm. But this time we are experiencing a higher conductivity. The outlet water pH & conductivity of Anion & MBP are 7.0 & 6.56 and .3 micro siemens/cm & 0.3 micro siemens/cm respectively. Can anyone help me to find the real cause of the problem?
