R
I can control the hydro power output via a motorized butterfly valve and controller. I can (manually) balance the power generated so that my meter stops and all the power generated is used in the local load. Of course as soon as the load drops I end up sending power back into the grid and paying for it as if I were drawing it from the grid.
How can I use a Square D PM-620 to control (limit to say 100ma) the reverse power flowing to the grid from a generator? But when the generated power falls off (due to local loading) the grid should carry the local load. Or in other words, since the PM-620 can accumulate kWh in signed mode, if I can get an output that reflects this sign, (by reading a register on the PM-620's Modbus?) I could feed this output to the generator power control valve and continually adjust the power generated to cover the local loading but no more.
Maybe Square D makes a reverse power controller to solve this problem? Any application notes out there telling me how to use a PowerMonitor-620 to stop reverse power flow?
If the grid and generator were all DC, a simple diode would solve this problem.
For more info about this Micro Hydro see: http://energyindependence-rob.blogspot.com/
