I'm trying to program an older Modicon analog input board. It's an B388-201. Can anyone give me some insight on programming a new analog board? I have to replace the board and I can't seem to get the program right.
I don't think that you have the correct part number. Do you mean B883-200 (Thermocouple) or B883-201 (RTD)?
I have fully documented and explained Modsoft programming example for the RTD module. It is a complicated procedure that must be run once to config the module. I can fax or email copy to you. Fax me at 403 243 4770 with your info.
