U
Hi, we have GE make Gas turbine frame 6FA having mark 5 control.
Hydraulic pump make: THE OIL GEAR
COMPANY,Milwaukee.
Hydraulic supply pressure switch low setting:
l63HQ1A &1B= 102 kg/cm2.
Accumulator(2 no's) pressure setting : 54 kg/cm2
When one try to change over Hydraulic pumps, at the instant of giving command "LEAD selection" to stand by pump it starts but SRV (Stop ratio valve-gas pressure control valve) having zero position.
From this we have doubt in accumulator pressure, it is found that one having 0 kg/cm2 & other at 50 kg/cm2.
I have doubt in mind
1) Is it due to accumulator problem?
2) How much minimum pressure required to have smooth operation of SRV,GCV & IGV.
Please guide in this matter.
COMPANY,Milwaukee.
