i have been observed physically during ratchet operation that ratchet teeth are engaged and 33 cs limit switch signal goes to logic 1 but the turbine shaft not rotated. anyway, i started the unit in this condition and after firing at speed almost 35%, i observed that clutch disengaged and starting motor has tripped accordingly.
same conditions occurred in the second start but clutch disengaged at different speed.
