I'm a rookie at this and need help.
I have 3 level floats as inputs and 3 sump pumps as outputs, an AB PLC5 and RSlogix500 software. The control scheme must be lead, lag, lag2 configuration and the pumps should alternate so the same pump does not run every cycle
I have the original relay control diagrams but can't seem to make the transition to PLC ladder logic.
many thanks in advance
coolclay
coolclay
