K
Dear All,
i am working with Frame 6 machine having Mark VIe control system.
I want to know is there any problem or it is OK.
machine is on part load(AUTO) with following data
CPD - 141 psi
IGV opening - 72 Deg
Exhaust temperature - 1041 Deg F
load - 31 MW (max capacity 36 MW)
IGV temperature control reference - 1056 Deg F
IGV temperature control curve Isothermal - 1069 (TTKGVI-constant)
Exhaust temperature control curve Isothermal - 1080 (Constant)
IGV minimum opening - 56 deg
IGV Max opening - 86 Deg
We have HRSG connected to GT and IGV temperature control mode is ON.
I understand that as per IGV algorithm, based on CPD value temperature control reference TTRXGV is calculating 1056 Deg F.
Now my question is IGV opening is normal. As i feel at this point, to increase the exhaust temperature(For HRSG) IGV should get close to minimum position, until the IGV temperature control reference reaches to 1069 Deg F.
Does IGV modulated differently in Part, Preselect and Base load?
Hope my question is clear.
Simply i want to know, why IGV is not getting close more to increase exhaust temperature, and what parameter decides the opening of IGV.
CPD - 141 psi
