We have two gas turbines; control system of one is Mark-II (TG-701) and other is Mark-V (TG-702). Currently Mark-II is on “ISO” while TG-702 is on “DROOP”. We are facing load variation problem. TG-702 picks load of 1.5 MW and TG-701 drops load of 1.5 MW simultaneously. Pressure transmitter is installed on inlet fuel gas of both turbines. Inlet Fuel Pressure of TG-702 shows increases up to 400 NMC and TG-701 shows decreases up to 400 NMC simultaneously. We conformed that no heavy machine / motor start or stop at that time.
We took real time plot of fuel gas from TG-702 (Mark-V), detail of observation is as below.
• FAG (GCV Servo current) shows almost constant reading while FAGR (SRV Servo Current) varies up to 4.0 units approximately.
• GCV_FDBACK and GCV_OUTPUT show almost constant value while minor changes observe in FSGR, GRV_OUTPUT and P2_Pressure.
From above mentioned detail, we come to conclude that SRV of TG-702 might be suspected. Please share your knowledge about that problem. Also suggest what other things we should look in such load variation problem.
