T
Tim Economu
If the max diameter where the sensor can be located is 7", then the circumference at that point is 22", and at 1024 pulses per rev, the reflector stripe (I see a alternating pattern of reflector and dark stripes) would be 0.021", which I believe would require a laser to detect don't you think? So for a normal optical tx and rx pair, maybe 0.1 resolution could be achieved which would require maybe 5 sensors, and a reflector stripe width of 0.1".... right?
I do like the one side assembly idea...that is the right way to go...
Tim
Tim
