Micrologix 1200 8-Pin Mini Din Connector
N
ner68
Does Any one have the above pin-out I need to connect the Micrologix to a PC. The 1200 Manual isn´t very helpful it only references to cables # to be bought from AB. Over US$70
Jerry Miille
You are stuck with the A-B cable. Even if you figure out the pin assignments for the Mini Din, it is not a standard plug. The 8-Pin Mini-Din you get from Radio Shack will not physically plug in.
Jerry Miille
T
Theo Baarslag
I couldn't find any information so far on it either, so my company has ordered one of those cables. If we have it, I'll see if I can open the connectors and see what's inside. But if it is sealed or molded in one piece, I guess you're out of luck from this end.
I don't like paying 70 dollars (or the equivalent in euros), discount or not, for something that we don't have much use for, but if the alternative means there is a chance of messing up or destroying a production machine, the choice is easy. For research and/or development / testing purposes that might be different though.
KR,
Theo Baarslag
PLC-/CIMSpecialist for IAMS Europe bv
The Iams Company, makers of superior dog- and catfood
www.iams.com
You can use the pin connection diagram that you can find in AB catalogue. I do not remember the cat no. You have to find a mini din connector with split metal giudes and remove one of them (available in the market) and wire up the cable.It works for me for the past few years.
Only a few dollars.
regards
Sekar.
Please look at A-B Manual for 1200, under chapter "Communication Connections", page 4-13.
There you can find pin-out and wiring diagram for 1761-CBL-PM02 cable, the one that you need.
The name of the file that I have is 1762-um001b-en-p.pdf
Alan Vrana
ScienceOfficer
That pinout is published in many locations, e.g.,
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/FC505C604E68154085256AFB006AC7C7?OpenDocument
I found that one and others by searching the KnowledgeBase with "pm02".
However, you should consider purchasing a 1761-CBL-PM02 (US$50 list price), because the DIN socket on the MicroLogix 1200 is deeply recessed, and a DIN plug designed for solder or crimp connections will probably not fit. (This is not a problem for other products that use this family of cables.)
Hope this helps!
Larry Lawver
Rexel / Central Florida
