Hi all,
This is my first post since joining the forum. I have worked in the hvac industry for 16 years swapping many bms components and a time served refrigeration engineer and now have been trying to further my knowledge of the workings behind the scenes.
I've a modbus rtu setup for testing, I'm trialing a connection to a mitsubishi electric frd700 inverter direct from my desktop via an rs485/USB converter on comm3.
I can interface with the drive via modscan64 and manually alter the binary registers to signal the drive to run, stop and vary the frequency etc. No problems.
I have a trial of quickhmi, I have setup the data source correctly but am struggling to communicate with the drive. Slave id , baud rate, parity etc all match modscan64 settings. The drive is set as a slave in the hmi. The register I'm trying to access is hr 9 (40009) I'm referencing it as hr8 with a byte variable type. Then trying to write the hex conversion of the new binary byte to the register.
Any advice would be helpful!
