Hi, I'm new to modbus world.
Thank you in advance, I know that this some have a solution to my problem.
I have two slaves that communicate with a twido plc using Modbus RTU, and i want to read and write some registers in those slaves. the problem is that those registers are Float, like temperation and setpoint.
<b>Moderator's Note:</b> <i>I think temperation maybe temperature.</i>
for example, in the list of the modbus registers, i want to read the temperation that has two registers 0x3 and 0x4 and they say it's a float register. also i want to write a setpoint that has also two registers 0x101 and 0x102.
for reading the registers, i configure the macros and everything. i thought that, if the registers are float and the response are words, i have to use the function ''CONCATW'' to concatenate two words to a single doubleword. then convert this doubleword to floatword. Am i doing it right? if not how can i do that in twidosuite?
Best regards,
Hicham.
Best regards,
Hicham.
