I have a PC, a PLC and a Temperature Controller in the same modbus network. The PC requests information from the PLC (so PC is master), and the PLC requests information from the Temp Controller (so PLC must be master). Can this be done?
A | Modbus Multi-Masters | Modbus | 1 | |
D | Multi Baud Rate on the Same RS485 MODBUS RTU Bus | Modbus | 13 | |
K | Data transfer of Eurotherm MINI8 multi loop contoller over MODBUS TCP/IP using labview | Modbus | 0 | |
C | Multi-Slave Modbus Network Problems | Modbus | 3 | |
D | Multi-turn absolute position with Modbus RTU | Modbus | 2 |
