I have an AC motor with a Permanent Magnet rotor. I want the motor to come to a quick stop when power is removed. I have read the thread about injecting DC into the windings, but that would not work here because I will have no power whatsoever.
In my research I saw a few mentioning about wiring resistors across the armature windings (one resistor between each phase) would provide braking action. Since I have a Permanent Magnet, so I my magnetic field is obviously maintained, so this sounds like it might work. And I would accomplish this by using N.C. contacts on the same contactor that would cut power to the motor with its N.O. contacts.
I know the inertia of the motor+load assembly. I know the speed from which to stop from. I know
the time in which I want it to stop.
But, how do I size the resistors (resistance and power rating)?
Thank you very much for any information.
