Dear all,
We have 2 Nuovo Pignone MS5001 gas turbines installed in our site for the past 10 years. Normally, those turbines are running on gas fuel. Occasionally (once every 3 months or so) they will be switched to liquid fuel firing due to the shortfall in natural gas supply.
Since installation, we had a problem with liquid fuel firing because the tubing connected to the liquid fuel check valves before it goes into the combustion liner always leak. In the past, teflon tape was used to seal the connections. However, recently we understood that teflon tape is not suitable for high temperature applications such as this. We changed teflon tape to loctite. It ends up that the leaking still persists. 6 out of 10 tubing assemblies leaked and the worse leak is 1 drop every 5 secs which is pretty bad.
We have tried to take out all of them to tighten and to perform pressure tests before. However, this problem still cannot be resolved. I would like to know whether anyone else has experienced similar problems before and how should we work to resolve this issue. Thank you very much.
Best Regards,
Dawei
Best Regards,
Dawei
