R
I need to control a boiler from a PC via the OpenTerm protocol. The protocol uses Manchester encoding and some microsecond level timing is required so a PC is not going to cut it. Certainly not if it has other tasks and is nit running a RTOS. An extra piece of hardware will be required.
I've been searching ... and searching but so far I haven't found anything on the net.
I'm now thinking to implement the interface using a microcontroller (PIC) speaking OpenTerm (master) on one end and on the other end TCP/IP, HTTP or maybe ModBus.
Is there anyone who has already done this and is willing to help me with line driver hardware and protocol intricacies?
Thanks in advance.
Thanks in advance.
