Hello All,
I am trying to import Graphics to my PanelView 550 (Touch Screen Only) application. I am using PanelBuilder32 ver. 3.7 and using the standard ISA graphics that come with. I want to show devices as on so I export the graphic, open in paint, fill in the graphic, rename and import the new graphic. I then use a multi-state indicator and make the "on" state of the bit in the PLC (It is actually a SCADAPack and the PanelView is Modbus capable) set to my imported graphic. It looks fine in PanelBuilder but once I download and turn the bit on in the PLC, the graphic is distorted. Can't seem to figure out what I am doing wrong. It has worked in the past for me but using a PV600. Is this a bug?
Any response would be appreciated. Thanks,
