E
Strictly speaking does MODBUS only allow for the passing of positive integer data? I have an application where a DCS is to communicate with a PLC via MODBUS. Some of the “analog” points are positive integer values ( e.g. 0-100 PSIG ) where the variable changes in increments of 1 PSIG. No problem – a two byte holding register with a “range” of 0-65535 will pass this right? What about power factor which has a range of negative one to positive one ( -1.0 to +1.0 ). Does MODBUS have means of using a 2’s comp scheme or scaling? What about fractional values?
Thanks in advance -
Thanks in advance -
