Large water treatment plant(20Meglitres/day), has inlet flowmeter inputing 4-20mA to PLC, need to control output of PLC (4-20mA) to small chemical dosing pump(via VSD)with pump speed tracking inlet flow ("Flow Paced Dosing"). Is PID ok?
am writing functional spec for client approval which will also be used by my PLC/SCADA programmer (so it needs to actually work). need to control the speed of the new pump so it tracks the inlet flow of the plant using inlet flowmeter, and delivers the right amount of chemical back into the inlet flow (only a few l/h). am using allen bradley SLC505 networked to CITECT SCADA. not sure if i should use proprotional only,prop & integral or full PID (Derivative control not my strong point back in college)or directly link signal from flowmeter to the 4-20 input to the pump motor VSD (pump does have 0-100% adjustable mechanical proportional output)
the dosing rate (mg/L)will entered by an operator to SCADA, an algorithm in PLC will calculate a setpoint based on:
Dosing Rate - mg/L
Plant inlet flow - ML/Day
Chemical concentration - mg/L
have already worked out algorithm to determine the setpoint, i think that i should have some proportional control justin case pump needs some speedin up, but would integral or derivative help?
inlet flow to plant does not change very rapidly except for stormy weather when it can quickly increase by 50%.
Dosing Rate - mg/L
