I would like to use your professional opinion in assisting me in possible advice and direction on the project that I am working on. I would like to build a Plastic Bottle Line counter that would count how many bottle went through a specific point with multiple sensors on a single line. This most likely would be photoelectric sensors that would be placed in strategic locations on the line that would read a count as a break in a light beam. The sensors should be connected to PC for interface via RS-232 and there should be software/program that would read the output from sensors and write the count/data to a file.
Potentially we have plants that have as many as 25 lines at one single plant that will need as many as 4 or 5 sensors per line. To save money, if possible, I would like to interface the sensors directly to RS-232 on PC running Linux. I realize that I might have to have multiple PCs per plant as you can only get so many RS-232 ports per PC, but I would like to minimize that number if possible.
After implemented a line worker should be able to use a web interface to select a bottle type to run on that particular line and start the counting process. A PC in a centralized location will then pickup the data from all of the line PC’s from all of the plants via already existent network and store the results in a SQL Server to provide Management reports and data.
Do you have any ideas or suggestions for me? I can use all the help you can provide to me. Thank you so much for taking your time to read my e-mail.
Jake Rog
Jake Rog
