hi all
i have measuring system contain from coriolis flow meter ,pressure and temp transmitters and flow computer( floboss s600)
my problem is some time the reading in flow computer is wrong
Normally, the number of pulses arriving from the meter is eight digits, but in one second it receives ten digits ( wrong pulses)
The meter is working fine and I don't know the reason for these but I suspect that there is something wrong with the flow computer
So that the reading jumps from about 4000 thousand cubic meters per day (as a correct reading) to (70 thousand cubic meters per day).
Note that this situation recurs for days, stops, and then reappears
thank you
thank you
