I have an application where there are two hydraulic cylinders that push product into station in a machine. The problem is that how the machine is designed now it at times will push uneven and calls jams or racking. We are planning on using linear transducers on the hydraulic cylinders to sense there true position and we are
planning on using proportional value on each cylinder to controll them. This machine is controlled by a Allen Bradley PLC-5 and my question is this. Is there any easy plc-5 command that can read these two linear inputs and control each output to allow the machine to push even until the cylinders are fully extended. If anybody has any ideas of how to program this with a PLC-5 I sure would like to hear from you.
Thank You.
Thank You.
